Hi,
So after 10 years of using VDJ i experienced a crash twice yesterday, wondering what it could be and if i can find the log files. first it crashed when i selected "mono" output in the middle of a set since the recording was poor on one channel. the song kept playing but i lost all midi control to my American audio versadeck. had to restart VDJ to gain control, second time it happened while i was loading a track to the right deck, vdj froze and sound cut off. again had to restart. any help would be appreciated. FYI i have always used the versadeck on private events since 2014
Device specs
Device name Chadster
Processor Intel(R) Core(TM) i7-8565U CPU @ 1.80GHz 1.99 GHz
Installed RAM 16.0 GB (15.8 GB usable)
Device ID EE9545F2-AD75-47FD-8145-51A0CF7CEFAE
Product ID 00330-52719-87221-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch Touch support with 5 touch points
Edition Windows 10 Pro
Version 20H2
Installed on 2021-03-13
OS build 19042.1288
Experience Windows Feature Experience Pack 120.2212.3920.0
VDJ build V 8.5_64 b6747
Device specs
Version 20H2
OS build 19042.1288
geposted Sun 07 Nov 21 @ 3:03 pm
Bump
geposted Tue 09 Nov 21 @ 4:05 pm
Crash reports get set to Atomix support automatically, if you are online at the time, and you have the default settings set
geposted Tue 09 Nov 21 @ 4:16 pm
Since in both cases you mentioned there was no crash (since you said you could still manually restart), no crash report was logged either.
geposted Tue 09 Nov 21 @ 4:38 pm
well both times when the controller got stuck i closed VDJ, if thats what u mean.
geposted Tue 09 Nov 21 @ 4:42 pm
do u know the setting sir?
having exact same issue .... what controller are you using? Im using a ddj sx... I went as far as to replace all cables , take the computer in to be tested and had it cleaned too. Its like since the sound car layout changed something else changed too. in all modes i only get 2 min before I crash . Some times i don't even get that far.
geposted Wed 10 Nov 21 @ 9:07 pm
this was an american audio versadeck, but after the 2nd restart it played nice all night. first was when i switched the sound to mono in VDJ, i have a custom button mapped for that when i go into venues that have a mono setup, next was when i loaded a track into the right deck. but i restarted both the controller and the VDJ, then it played nice for the rest of the 2 hours.
geposted Wed 10 Nov 21 @ 10:42 pm
So the same issue yesterday. 4 hour set in the 3rd hour vdj got stuck. No sound just stuck. Closer vdj and open back up and played till close without any issues. This time it's a ddj sb3. Anyway to know what is happening. On the latest build.
geposted Sat 02 Apr 22 @ 6:49 pm
Do you use ASIO?
Could you take screenshots of your audio parameters and post them here?
geposted Sun 03 Apr 22 @ 10:18 am
djcel wrote :
Do you use ASIO?
Well the SB3 does not have ASIO Drivers so its set to WASAPI
geposted Mon 04 Apr 22 @ 3:08 pm
