Topic: deks A&B
since the latest update. If I choose A or B on a Denon sc6000, the other always changes with it. separation not possible? using with x1850.
geposted Tue 16 Nov 21 @ 8:20 am
user24521956 wrote :
since the latest update. If I choose A or B on a Denon sc6000, the other always changes with it. separation not possible? using with x1850. MacOs Monte Rey
You mean the 2nd SC6000 device follows the Deck selection of the 1st one ?
Can you go back to a previous Build and check if the issue is indeed due to an update ?
https://virtualdj.com/download/build.html
Or by update you mean OS update ?
Thank you bro. The problem was the new Virtual Dj update. Didn't know where to restore older versions. Thanks to the link I reloaded the last version and now everything is running as before.
So, Build 6732 (previous Release) is working fine, but Build 6747 (current one) is not ?
Will try to check here, but only have a single SC6000
BTW, in Settings->MAPPING tab, what do you see as "Deck" for each device ? I believe you should get "Automatic(1)" and "Automatic(2)" for each of the 2.
