For some reason, I cannot select any Jpg for slideshows anymore. So now if there is no music video playing, I just get a black screen as I can't select a folder of slides.
Anyone know of a fix?
geposted Sun 19 Dec 21 @ 9:39 pm
Nobody else had this experience then?
geposted Tue 04 Jan 22 @ 2:51 pm
Works fine here.
You have Slideshow selected as "video Source" ?
VideoAudioOnlyVisualisation in Settings->OPTIONS says "Slideshow" ?
If u click on the cog icon next to Slideshow, you should get the FX GUI at the right side of Browser and a button to select Folder. Doesnt this work for u ?
geposted Wed 05 Jan 22 @ 1:42 pm
Cheers for the reply and sorry for the delay in mine.
I've changed the videoAudioOnlyVisualisation to Slideshow and also tried to select slideshow in the video FX panel. When I go to chose the folder, all the jpg files are greyed out whereas before they were selectable.
Still can't select any slides to play when there are no music videos playing....
geposted Thu 13 Jan 22 @ 12:14 am
Dunno what I did but all sorted now.
geposted Thu 13 Jan 22 @ 4:02 pm
