Hello I just bought VirtualDJ Pro and it wont allow me to log in. It gives me the cannot connect to servers. Ive already installed and reinstalled several times with no luck. I also checked my firewall and no luck eighter. Any help ?
geposted Sat 25 Dec 21 @ 7:18 pm
check yous hosts file if on windows to see if the virtual dj servers are blocked
this almost always happens if you had cracked software installed in the past
geposted Sat 25 Dec 21 @ 9:33 pm
geposted Sun 26 Dec 21 @ 9:59 am
Thank you.
geposted Sun 26 Dec 21 @ 5:22 pm
