MY OLDER VERSION VIRTUAL PRO 7.2 WORKS JUS FINE BUT NOTICE
CUEING ISSUES WITH RIGHT SIDE OF DN-MC6000 SINCE SWITCHING TO VIRTUAL PRO INFINITY, COULD IT BE A SETTING ISSUE? HELP PLEASE
geposted Sat 01 Jan 22 @ 7:17 pm
Please don't shout.
You've not made clear whether you're still using VDJ 7 or have now moved to VDJ 8.
Please explain what exactly are the "cueing issues" that you're having.
geposted Sat 01 Jan 22 @ 7:58 pm
I have two laptops one with Virtual 7 and the other with Infinity Pro and I alternate between them depending on the event, my que points are fine with the Pro 7 on both left and right channels but when I use Infinity Pro the right channel cue points does not respond with precise / on point timing.
geposted Mon 03 Jan 22 @ 10:45 pm
Any suggestions how I can fix that issue?
geposted Mon 03 Jan 22 @ 10:48 pm
