Hi
Is there a way to make the BPM slider lever on screen to flash once when there physical controller matches its position and starts to action abpm change? I'm having a hard time seeing when it engages with the vdj BPM slider position and my controller has no zero indentation to do it by feel and quickly reset the hardware to +-0 BPM.
geposted Tue 25 Jan 22 @ 1:30 am
Perhaps you want to turn off that feature?
Look for controllerTakeOverMode and controllerTakeOverModePitch in VDJ settings
geposted Tue 25 Jan 22 @ 5:06 pm
Thanks, these are useful features, but often because I dont use the relative mode, I have to slide the controller tempo lever to the point it matches the position on screen and its not clear when these matches until it actually starts changing tempo.
It might be that I should perhaps use relative mode instead.
geposted Tue 15 Feb 22 @ 12:31 pm
Create a visual or a custom button (or even use it on a LED) and give it this code:
param_equal pitch_slider pitch
geposted Tue 15 Feb 22 @ 1:07 pm
