Raised this several times now. Is there any particular reason why you can only be signed in to the website from one device?
For example if I switch between phone and desktop I get logged out.
No other websites I visit do this.
geposted Tue 25 Jan 22 @ 3:14 pm
Should be 2 devices
geposted Tue 25 Jan 22 @ 3:38 pm
Logging in to the website its one. Software is two.
geposted Tue 25 Jan 22 @ 4:45 pm
No, should be 2 browsers for the website, independent of software login. (Works fine here with phone and laptop)
geposted Tue 25 Jan 22 @ 4:59 pm
OK, will check later but for me it's one device.
But why the restrictions on signing in?
Rune said he'd look at it some time ago but still the same
geposted Tue 25 Jan 22 @ 5:01 pm
Just checked and it's definitely one. Why?
I can sign in to literally every other website from multiple devices and browsers.
geposted Tue 25 Jan 22 @ 5:30 pm
Its just a choice, security .. Currently set to 2.
And many places with similar measures.
For example Zoom etc
geposted Tue 25 Jan 22 @ 5:46 pm
Maybe so, but are your login details on those sites also used for a software license?
geposted Tue 25 Jan 22 @ 6:16 pm
The software licence is completely separate to the website login as you need to sign in within the software to activate it. Nothing to do with tbe website at all.
As I stated previously when you are signed in to the website (not the software) then change device it requires you to login again every single time. Every other site I visit I can be logged in from various devices without issue.
geposted Tue 25 Jan 22 @ 6:38 pm
