Is it possible change the order in which a song are played? I imagine to split the song in pieces based on beats and combine them in different order, like a programming thing. A sort of programmed remix. There is something like that?
geposted Sat 29 Jan 22 @ 9:06 am
You can use hotcues and action POIs to jump from one point of a song to another
geposted Sat 29 Jan 22 @ 9:46 am
actionPOI is one way here's another.
https://www.youtube.com/playlist?list=PLElI5UuIUibOAknXcVweAILtdCrFyLQQu
geposted Sat 29 Jan 22 @ 10:01 am
hello. I can't fine routineSP plugin in VD2021. Shoud it be downloaded from elsewhere? Thanks.
geposted Sat 29 Jan 22 @ 12:36 pm
it's a padpage>others
geposted Sat 29 Jan 22 @ 12:48 pm
thanks for the hint. There is a way to script how the cue points are to be played? I mean somethins like that: play from cue1022 to cue2011
play from cue 3012 to cue4004
etc.?
scripting instead of recording
thanks
etc.?
thanks
geposted Sat 29 Jan 22 @ 2:32 pm
with routine, no, with apoi, yes, cycle a var, query the value if desired step jump to wherever rince and repeat.
geposted Sat 29 Jan 22 @ 2:41 pm
thanks for your reply.
there is a way using action point to start a loop and repete it 4 times? for example.
thanks
thanks
geposted Sat 29 Jan 22 @ 3:35 pm
loop 1 & wait 4bt & loop_exit
loop 2 & wait 8bt & loop_exit
Basically this formula:
loop N (amount of beats) & wait 4xN bt & loop_exit
geposted Sat 29 Jan 22 @ 3:59 pm
