Something has happened to the FX button mapping on my Denon MC4000, and 2 out of 3 FX buttons do not work as they used to. It seems that the mapping has changed, and loading factory default makes no difference. I couldn't find out how to map them so that they work as normal, ie. when pressing the FX button, it will activate the effect on that slot. Now it just recycles the effects on slot 1. See screenshot of that current mapping. How should I set it?
geposted Tue 01 Feb 22 @ 3:14 pm
It looks fine
It depends on if you are in 1 fx mode or 3 fx mode how the controller will act, so that is probably what is confusing
geposted Tue 01 Feb 22 @ 3:28 pm
Do you mean this one here, it's on the three mode:
geposted Fri 04 Feb 22 @ 5:57 am
Here is what I mean:
geposted Fri 04 Feb 22 @ 2:29 pm
Ah yes, thank you, that was it.
I still don't understand how that was ever changed, as I don't remember seeing that option before, and I only use "Performance" layout, where that option is not visible.
Pro layout
Performance layout
Pro layout
Performance layout
geposted Sun 06 Feb 22 @ 5:52 pm
Dont know why - but I'm glad you got it fixed 😊
geposted Sun 06 Feb 22 @ 6:38 pm
geposted Sun 06 Feb 22 @ 6:40 pm
In past when in Fx3 mode on Pro skin and one toggles to Essentials and back, the Fx3 mode is NOT correct. don't know if this is part of the issue. And have not tested to see if this is still a current issue, or with Performance skin.
https://virtualdj.com/forums/238040/VirtualDJ_Technical_Support/Mulit-Mode_Fx__goes_into_an_Undocumented_Mode_when_Toggleing_to_Essentials_Skin___back_to_Pro.html
geposted Mon 07 Feb 22 @ 3:19 am
