Hello, not strictly VDJ issue, although I will be using it as my software. I'm not super clued up on this but is there a way to utilize my Korg Kaoss Mixer km-2 together with my Pioneer dj mixer ddj sx2, to enable to use the Korg audio effects on either master out or 1-4 Channels ? Playing music files from my desktop PC. The sx2 has a soundcard, my pc has a soundcard, (although I am currently using headphones plugged into an AudioQuest DragonFly USB stick on back on PC). Abit confused about the right inputs and outputs and cables I might need. Do I have the right hardware to do this? Many thanks in advance.
geposted Fri 04 Feb 22 @ 12:54 pm
If you have an SX2 I can't understand why you have headphones plugged into a USB interface...
You can use the SX2 as the main controller & audio interface, then send the SX2 output into the Kaoss Mixer. Output of the Kaoss mixer goes to speakers.
geposted Fri 04 Feb 22 @ 5:58 pm
