Hi Folks Ive had a macbook and im now moving over to dell xps ,
just need bit of advice on the leads which I can use ......,On the Macbook it had 3 usb ports which I was using 3 of them with external hardrives etc , but now looking at dell xps there only 2 usb ports one of them im using the wireless mouse and the other is external usb , would it be possible to use hdmi to the controller or type c usb to the controller ,just want to ask before I purchase the leads and which one is better to use ....my controller is a XDJ-RX thank you in advance
geposted Fri 04 Feb 22 @ 5:06 pm
Get a bluetooth mouse and use the USB port for the controller.
geposted Fri 04 Feb 22 @ 5:33 pm
ive already got the mouse lol
geposted Fri 04 Feb 22 @ 5:41 pm
What's funny? You're asking for advice. He gave advice.
You say that currently one of your two USB ports is occupied by the wireless mouse. If you use a bluetooth mouse instead (or use the built in pad) it will free up the port.
If the XPS has USB C then you actually have three USB ports, yes? Buy a USB C hub that provides a bunch of USB 2/3 ports.
geposted Fri 04 Feb 22 @ 5:49 pm
BTW: Forget the HDMI port for anything else than a secondary display.
Also you can get a USB hub, or get a USB type C to USB type B "printer/scanner" cable to connect your controller directly on the type C port.
geposted Fri 04 Feb 22 @ 6:07 pm
wasnt finding anything funny GroovinDj , I all ready purchase the mouse with the laptop and yes I have usb trailing extention 4g (powered) and put 3 external harddrive but it dosent seem to work ,that why im asking if I can use hdmi or type c to my controller
geposted Fri 04 Feb 22 @ 6:12 pm
Thank you PhantomDeejay
geposted Fri 04 Feb 22 @ 6:14 pm
Best not to write LOL then.
geposted Fri 04 Feb 22 @ 6:49 pm
