Hi everyone.
I am using 2 laptops, a main one and a back up, if I log into vdj on my back up laptop, should vdj mirror my main laptop for things like layout, saved playlists etc, if not is there a way to do it?
I presumed using the same log in on my back up laptop that it would but it isn't, I use my main laptop regularly but the back up not so often so it would be good if it was possible to have my back up match the main one when I log in..
Thanks in advance :)
geposted Sun 06 Feb 22 @ 7:41 pm
No, the login is just to verify that you have a license
But your music or database or settings or anything like that are not stored centrally
They exists on each individual laptop
Can you move the information?
Yes, you can copy it over from one laptop to the other
Or maybe use the backup/restore feature in VDJ
geposted Sun 06 Feb 22 @ 9:03 pm
OK, thankyou for that, much appreciated:)
geposted Sun 06 Feb 22 @ 9:32 pm
