@adion
In Build 6833 the Info Panel looks:
You don't see this in normal resolutions.
Im using a half of an 3840x2160 (1920x2160 Window) Screen.
OS= Win11
HW= Intel NUC 8th Gen Core i5, 16GB Ram
On my Macbook Air (Apple Silicon, Monterrey 12.2) the build is ok and the Info Panel looks as in b6800.
OS= Win11
geposted Mon 07 Feb 22 @ 11:17 am
Still switches to 2 lines per entry here if there's enough vertical space.
geposted Mon 07 Feb 22 @ 11:43 am
