Good evening,
i want to change all playing shaders from both decks via action cue,
but only the activ deck is changing at the moment.
effect_string "audioonlyvisualisation" 1 +1 & deck 1 effect_string "audioonlyvisualisation" 1 +1 & deck 2 effect_string "audioonlyvisualisation" 1 +1
geposted Mon 14 Feb 22 @ 7:33 pm
aov [audioonlyvis...] is a deck master effect slot.
geposted Mon 14 Feb 22 @ 7:40 pm
Okay thx,
but how can i change the deck effect?
Change both decks to the same shader, befor the dualshader has two different shaders.
deck left effect_string "shader" 1 +1 & deck right effect_string "shader" 2 +1
geposted Mon 14 Feb 22 @ 8:01 pm
I don't know why you're wrapping the deck number in quotes, it's not needed
geposted Mon 14 Feb 22 @ 8:25 pm
Becouse vdj show me that the string was wrong.
But now i only use left and right.
geposted Mon 14 Feb 22 @ 8:38 pm
Yesterday i test the Action Cue with this string but is dosnt work, complettly
now the left deck is changing at the cue, but the dualshader dont work like it is,
it waits till the next cuepoint, the right still on the same shader all the time.
I want to forward both shaders if dualshaders is running,
because in some tracks the change is on the first beat, but this is not the perfect position,
and only the playing deck is changing, but it looks better for me, if both change at the action cue point.
Deck left effect_string "shader" 1 + 1
geposted Wed 16 Feb 22 @ 9:58 am
