Hi, I am playing vdj through laptop, audio output through amps and speakers and video output through hdmi to a modulated which converts it to a coaxil cable to connect to my TVs, my problem is this causes a slight delay of about a second on the videos, I have spent ages trying to adjust the video delay but can't work out if I'm supposed to be doing plus or minus, whatever I try I can't seem to get it right. Any suggestions please
geposted Sat 19 Feb 22 @ 6:49 pm
Put a delay on the audio signal so it matches the delay presumably caused by the HDMI conversion.
geposted Sat 19 Feb 22 @ 10:11 pm
Ok, I will try that. Yes the delay is caused by the hdmi conversion. Thanks for the help.
geposted Sun 20 Feb 22 @ 9:37 am
Looking for an audio delay setting but can't find it anywhere
geposted Sun 20 Feb 22 @ 6:11 pm
Just type delay in settings
geposted Sun 20 Feb 22 @ 8:26 pm
Tried that, only video delay comes up
geposted Mon 21 Feb 22 @ 4:48 am
Add audio delay ?? that's definitely bad to do so, unless you are not mixing live and playing some mixtapes.
Best would be to find some hardware solution with low video latency/delay.
If not possible, the video_delay action can take negative values (in ,milliseconds) so try ..
video_delay -1000 (1000=1 sec)
on a custom button or set the negative value in videoDelay setting
geposted Mon 21 Feb 22 @ 12:24 pm
Thanks, so if the video is behind the music I have to put a - value?
geposted Mon 21 Feb 22 @ 1:14 pm
Yes
geposted Mon 21 Feb 22 @ 3:35 pm
