Is it possible to play each stem through a seperate output channel so that it can be mixed externally or played though a different speakers as a kind of pseudo live sound audio?
geposted Mon 28 Feb 22 @ 11:13 pm
I guess this isn't possible then. I know it's not your typical use case.
geposted Tue 08 Mar 22 @ 4:52 pm
You can split it up and prepare it as separate tracks using either the CDJ export function, or an audio editing software like Audacity. Then you can load the separated stems on separate decks/channels and play them independently
geposted Tue 08 Mar 22 @ 9:35 pm
