1) How do you name a saved loop pad? Currently the pad shows what time in the track the loop is activated
2) How do you change the bpm counter to show one decimal, for example 128.1
Thanks
Thanks
geposted Fri 04 Mar 22 @ 2:05 am
1 is setting, savedLoopDisplay, you can set the name in the poi editor.
2 requires a skin edit.
geposted Fri 04 Mar 22 @ 2:35 am
Where exactly is the savedloop setting? When I right click on the saved loop pad it opens the poi editor. Name 'loop intro', type 'Saved Loop' , cue 'marker only'. Clicked X on top right of poi editor. Still no change in the saved loop pad. Still shows time the loop is activated
geposted Fri 04 Mar 22 @ 10:17 pm
in options & tweaks
geposted Sat 05 Mar 22 @ 3:20 am
and an alternate way to change the display mode of a pad-page is from the menu dot..
see screenshot for saved loops pad page:
https://gyazo.com/c8119e9cb0bac3afa5404ef0dfdefb41
geposted Sat 05 Mar 22 @ 9:07 am
Where exactly in the options and tweaks is the setting?
geposted Sat 05 Mar 22 @ 6:18 pm
search for it.
geposted Sat 05 Mar 22 @ 6:36 pm
How do you change the bpm counter to show one decimal point? What is the text that should go in the xml skin?
geposted Mon 07 Mar 22 @ 1:10 pm
search for
"%Pbpmex"
change to
"%Pbpm"
in default pro there are 4 instances.
"%Pbpmex"
change to
"%Pbpm"
geposted Mon 07 Mar 22 @ 1:44 pm
Great, thanks
geposted Mon 07 Mar 22 @ 3:43 pm
