I am having trouble removing instrumental and vocals from a song i keep clicking on detune and clicking vocals my layout is on pro and it wont work can anyone help please.
geposted Sun 13 Mar 22 @ 8:30 pm
detune is a looping plugin
geposted Sun 13 Mar 22 @ 8:32 pm
I have tried updating detune however it says unable to write the update then when I try again it says download failed
geposted Mon 14 Mar 22 @ 12:23 am
What locodog is saying is that detune is not for removing anything. It's a looping effect
You should be on for instance the stems padpage and using the pads to remove parts/stems
... and of course first make sure the stems separation is enabled on your setup, and has been run either automatically or manually on the track
geposted Mon 14 Mar 22 @ 7:15 am
Use the built in stems feature ;-)
geposted Mon 14 Mar 22 @ 10:13 am
