Can anyone help me with why the latest update of VDJ all of a sudden takes FOREVER to "browse" my folders on my hard drive? Is there a setting that changed or anything I can do to speed up the process?
I go to a folder and it is "browsing" like 30 seconds or more. I appreciate any help =)
geposted Sun 13 Mar 22 @ 11:43 pm
External drive perhaps?
that is gone "to sleep", and has a bit of a wake up time
geposted Mon 14 Mar 22 @ 10:14 am
I thought that could be it but it will do it as soon as I plug the drive in and bring up VDJ so I kind of eliminated that as an issue (maybe still could be one though 🤔) Isn't there a way to tell the drive not to go to sleep?
geposted Mon 14 Mar 22 @ 4:56 pm
Try the beta version that is addressing some issues with Mac in that regards.
Sent you link to the beta in PM.
Post feedback in this thread if it works better or not ;-)
geposted Mon 14 Mar 22 @ 5:48 pm
OK, thank you! Will do.
geposted Mon 14 Mar 22 @ 7:57 pm
I am not sure if it sent you a message back but I am getting a "Sorry, the link you have used is not valid anymore." when I click on the link you sent me.
geposted Mon 14 Mar 22 @ 10:04 pm
Ah yes, i will send you a new link
geposted Mon 14 Mar 22 @ 11:01 pm
Seems to be working better. Thank you =)
geposted Mon 21 Mar 22 @ 5:39 pm
Can I get a link to that beta too? I'm having the same problem . . . just updated to the latest version and now I can't even search for a file because it's stuck on "Browsing"!
(I'm on PC)
(I'm on PC)
geposted Mon 23 May 22 @ 8:19 pm
