Since day one the scratch haven't work properly. Little sluggish, latency and sticker drifty. I have search the forum, asked the staff, test all sorts of settings and no luck.
But finally i got it to work as it should and it's perfect.
Something was wrong in the firmware on the controller. I found on the interweb i little pdf how you should do a factory reset on the SX2!
After the reset, Bam! It works!!!
No lag, precise jog, movement backspin works and razer sharp scratch.
How to reset SX2:
Entet service mode: Controller off, hold left shift and Deck 1 and power on. After a few sec you are in service mode ( not the same as utility mode). Then press and hold both left and right sync for over 2 sec.
If someone have a similar problem on another type of pioneer controller it maybe could help with the same solution. Search for your controller and factory reset because I doubt it's the same technique and try.
Now i gonna scratch all night long 😀😀😀
How to reset SX2:
geposted Tue 15 Mar 22 @ 9:15 pm
Good good ;-)
yes drivers, firmware, software etc.. .should always be kept up to date ;-) good advice
geposted Wed 16 Mar 22 @ 10:19 am
