I had a weird problem the other day where I was playing.
Using latest VDJ free version which is linked to a Pioneer controller (basically just for the soundcard as it needs full version to use it.)
It always worked before and I just use the mouse to load songs and select decks etc.
It works but it's really unresponsive, for example if I use say the slider to control the decks with the mouse it takes a few seconds after clicking the mouse for the slider to move.
Same when loading songs or actually doing anything!
PC specs are good and using task manager I could see nothing obvious ie everything was well in the limits of the pc.
Was using a normal external HD with plenty of space left on it.
Any ideas please?
Thanks Danny
Any ideas please?
Thanks Danny
geposted Thu 17 Mar 22 @ 6:14 am
