bmac16 wrote :
The D2 Screens aren't working anymore since the last update. I get the Traktor Kontrol D2 screen rather than saying Virtual DJ
I just recently installed the latest version b7482 and everythings working fine over here.
geposted Sun 09 Apr 23 @ 1:55 pm
I am trialing VDJ with D2s as an alternative to Traktor. Started on my mapping journey but stuck on the first command 🤦♂️.
I'm wanting to select the deck from the top right FX buttons like my current mapping allows me too. DECK and the "invert_controllers" action obviously updates the screens well but only flicks between A/C decks. My numerous attempts to select a specific Deck using "FX_SELECT_x" Buttons and have the D2 screen reflect my selection have failed.
Anyone got any idea on how I could achieve such a thing? Thanks heaps
geposted Sun 24 Dec 23 @ 1:26 am
Does anyone else notice there is a small jitter on the small waveform while the track is playing, even on the default skin?
It's small so you can ignore it, but I tried to modify the skin (I put cue point numbers on the small waveform), and the jitter got a lot worse.
Does everybody see it? Anybody who knows what is causing it?
Thanks!
EDIT: found it! :)
If anybody wants to remove the jitter, change this line
<songpos class="songpos" x="+5" y="+55+5+40"/>
to
<songpos class="songpos" x="0" y="+55+5+40"/>
Thanks!
EDIT: found it! :)
to
geposted Fri 11 Jul 25 @ 3:43 pm
Is It possible to change the waveform colors to look more like Traktor Pro or Pioneer inspired Waveforms?
geposted Sun 14 Dec 25 @ 8:28 pm
Question on the december update, could I get the briefest overview in the changes.
I've just made a modification for somebody [I dl'd the skin from the site] and I couldn't figure out his picture didn't marry up with the skin xml, then I spotted the update was recent.
I might yet have to modify his older version if he doesn't like the update, so was there anything bugfixy or was it all cosmetic changes?
geposted Mon 19 Jan 26 @ 10:25 pm
Ah not to worry^, Guy is happy and the photo he had shown me was just from online, so the layout differences I was seeing make sense [and don't matter]
geposted Tue 20 Jan 26 @ 3:45 pm
Hi,
I posted this in the skins forum but just remembered the dedicated D2 forum. So below is my issue, it looks like it's been raised before, did anyone resolve it for Mac users?
About 5 times out of 10, when i start up my D2s, the screens don't recognise VDJ, the buttons all work but the screens get stuck on showing the original Traktor message. It makes not difference that I can tell if VDJ is started before the D2s or after.
Once I have one D2 running if i then start the second it will always get stuck on the traktor screen, the buttons will work.
I'm running VDJ v2026-m b9295, macbook 2021 M1 Tahoe 26.5, D2s firmware upto date. Although these issues have been happening with older versions of software.
I've tried having both decks connected to seperate usb ports, daisy chained, through a powered hub and it still happens.
Does anyone know a fix for this? Does it happen to screens on other devices?
Thanks
Bryn
Thanks
Bryn
geposted Tue 26 May 26 @ 9:20 pm
I have the same issue (blank screens / logo only). macbook pro m1, vdj v2026m-b9295. I found a workaround for that: Start Traktor Pro 4 for a while and then, after a few seconds, close it. I don't know why but for some reason running Traktor Pro makes the screens ready to work with vdj.
geposted Sat 27 Jun 26 @ 10:45 pm
It's likely some kind of communication from Traktor that wakes up the D2 screens.
Traktor starts, sees the D2 and says "Hello D2, my name's Traktor"
The D2 says "Oh hi Traktor, I'm going to enable my screen for you"
geposted Sun 28 Jun 26 @ 9:13 am
