I have a question about moving VDJ to a new laptop. I have moved over all of the files under "Documents\VirtualDJ". Is there a way to have the VDJ program look in the history to determine "last played" for the songs and find my most played songs and so forth?
geposted Thu 24 Mar 22 @ 9:34 pm
If you copied over to same location, also the music files, it should already be that way..
Is it not working for you?
geposted Thu 24 Mar 22 @ 9:44 pm
Unless your music files are located inside "Music" folder of your OS.
In that case you need to restore a backup of the database (VirtualDJ's built in function) so that it reads and updates the new location (because the full path of "Music" folder uses your Windows Logon username in the path)
geposted Thu 24 Mar 22 @ 10:18 pm
Whenever I get a new computer, I copy the VDJ Folder from my old computer and then paste it into the newly downloaded VDJ on the new computer. All my settings, cue point, images etc. are there. It looks and acts just like my old computer.
geposted Fri 25 Mar 22 @ 1:38 pm
Geht das auch von Windows zu MacBook?
geposted Fri 25 Mar 22 @ 4:13 pm
