Hi all does anyone know if there is a way to 'fit' (maximise) the VDJ window on my LG Ultra wide screen monitor? At the moment I drag it to an appropriate size from the bottom right of the window and position it to the centre of the whole screen making adjustments to ensure I can see and read everything.
I have the LG screen control installed which allows me to split the screen into various windows for multi tasking on different programs but VDJ will not snap into one window which means every time I click on a different window or program assigned to a different window VDJ automatically minimises - Not the end of the world but it would be great if there was a solution to be able to work on two windows at once.
Thanks for any solutions offered if indeed there is a solution !
geposted Sat 02 Apr 22 @ 12:10 pm
