I am missing some history in VDJ from my gig last night; but the entire list successfully synced to my set list under my profile on virtualdj.com. is there a way to sync it back to my laptop?
Thanks.
Thanks.
geposted Sat 16 Apr 22 @ 3:03 pm
Taking a closer look.. I am missing all my history for 2022! It is saved on my virtualdj.com account.. but not locally. I do have the checkbox checked. Any thoughts or hints are welcome.
geposted Wed 27 Apr 22 @ 11:50 am
Are other settings saved correctly? Can you still create new playlists?
geposted Wed 27 Apr 22 @ 11:52 am
Yes I can create new playlists without issue.
geposted Wed 27 Apr 22 @ 1:25 pm
Anyone have any further insight on this? I have an event this Saturday and would really like the selections saved to my local history.
Thanks in advance for any assistance.
geposted Fri 29 Apr 22 @ 10:28 am
writeHistory is set to yes? historyDelay value is normal?
geposted Fri 29 Apr 22 @ 11:05 am
Yes, I have not changed these settings in a very long time.
geposted Fri 29 Apr 22 @ 12:53 pm
You can see a History folder in Documents\VirtualDJ ?
Does it contain tracklist.txt and if so, does that have more recent history?
geposted Fri 29 Apr 22 @ 1:05 pm
It does not contain that file; but the karaoke from this past Wednesday saved correctly in the karaoke folder.
geposted Fri 29 Apr 22 @ 1:12 pm
OK I added an empty tracklist.txt file and a quick test indicates it is storing tracks in there and creating a history playlist with today's date. Thanks for the help and figuring it out.
geposted Fri 29 Apr 22 @ 3:10 pm
The tracklist.txt seems to disappear. I have not figured out exactly when it disappears; but without it the history definitely does not save.
geposted Mon 23 May 22 @ 10:27 am
