Hello,
I'm using both Virtual DJ & Rekorbox for playing music depending if I use Cdjs or a controler.
I'm on the PC version.
One thing very cool in VDJ is when I plug a USB key coming from Rekordbox I have immediatly my playlists and hotcues working right.
But, when I'm importing my hotcues with the Rekordbox database from my PC, I have a little gap in hot cues.
Is anyone have this kind of thing ?
Am I doing something wrong ?
Is it a knowing bug ?
May I stop Djaying and specialise in BBQs ?
Cheers
Cheers
geposted Sun 15 May 22 @ 12:32 pm
by "little gap", you mean that they differ in the exact Time Position (min:sec.msec) or you get a delay when you press a HC button ?
geposted Sun 15 May 22 @ 1:54 pm
Here is one screenshot. The blue one is the import from the local Rekordbox database.
The red one is the thumb drive generated with Rekordbox.
geposted Sun 15 May 22 @ 2:26 pm
Sorry, I have posted some new tests about Rekordbox cues on USB keys, but nothing wrong...
If you have a big key with lot of songs, you have to wait the program to import the cue songs (logic)...
Cheers
Cheers
geposted Mon 16 May 22 @ 6:57 pm
