Woukd it be possible to add one? The info is in tag editor individually but would be nice to sort in a column so I know which files to upscale or replace.
Thanks!
Thanks!
geposted Fri 27 May 22 @ 8:25 pm
+1 it should be a filterable thing.
geposted Fri 27 May 22 @ 8:57 pm
Just giving this a bump as I posted it on a Friday night and it got lost.
geposted Mon 30 May 22 @ 7:20 pm
It is not stored in the database, so it would have to be read from disk. It is also not trivial to get for all file types, so it might be quite slow.
geposted Tue 31 May 22 @ 6:37 am
Probably worth putting it in to see how it would work.
Personally I only have about 2500 video files. I can't find any other program to give me that info.
geposted Tue 31 May 22 @ 7:27 am
Would be a great addition!
geposted Thu 08 Sep 22 @ 6:50 pm
you can enable the columns in the windows file explorer for width and height of video files
just thought i would throw that out there maybe it helps if you want to weed out low resolution files
Frame height
frame width
are the columns to enable
Frame height
frame width
geposted Thu 08 Sep 22 @ 7:05 pm
It doesn't work in Windows. Gaps all over the place.
geposted Thu 08 Sep 22 @ 7:11 pm
working fine here
geposted Thu 08 Sep 22 @ 9:18 pm
Never ever worked properly for me
geposted Thu 08 Sep 22 @ 9:45 pm
