I cannot enter the login name to my audio server. Thew field is locked.
I cannot add an audio server.There is not button to add a new server address.
My license is VDJ Pro.
Mark Roberts
Mark Roberts
geposted Fri 27 May 22 @ 11:44 pm
screen shot of the radio server page in options please
all seems good on my end
geposted Sat 28 May 22 @ 1:27 am
Buttons do not work
Login field is locked.
geposted Sat 28 May 22 @ 2:12 am
The Radio Server is also working well for me as well, with update 6959.
I believe that you do not need to change Login field .. keep it as source
And it appears there may be a typo.. with an entry .. since for:
Server URL: you have included a port number of 9638 after the colon. The port number of your stream should not be there.. but in the Server Port: field. (which you have 8004) as the Port.
so the port should NOT be in the Server address.. and there are 2 different ports that you have used. . should be same.
(verify your server settings, from your stream provider)
Yes, there is NO button to add a new server address. (and assume you are asking about Radio Server, as that is what you have pictured)
One just changes the name of the Config: field, to say, "MyStream2" ,
Enter the new server's info.. and then click the save button, (left button in your photos upper white box you added)
to add new server to the drop down menu, for future use.
(the same way as saving/creating a new audio configuration or controller mapping in VDJ)
geposted Sat 28 May 22 @ 8:37 am
