hey all,
thinking about buying a VDJ home plus license, and notices that under the devices that can be purchased, there's two called 'MIDI32' and 'MIDI28'
are these generic MIDI controllers that can be mapped to any single device? i've tried googling their names, but have come up short, so I can only assume they're something specific.
geposted Sat 28 May 22 @ 8:36 am
Home plus licences are always a specific device, you buy the licence for the hardware you have because that's the only way it will work.
geposted Sat 28 May 22 @ 8:45 am
thank you for the quick reply, but it's strange that there aren't any products on the product page by that name. the only thing that comes up when googling both names are a MIDI PCB called the 'MIDI 28 development board' and a Windows DLL called midi32.dll
It really does seem like they're meant to be mapped to any midi device, but only allows for one to be connected, but i'm likely wrong.
geposted Sat 28 May 22 @ 8:54 am
These are probably specific "OEM" controllers, where the same controller is sold under different brand names.
geposted Sat 28 May 22 @ 9:02 am
huh, i didn't consider that. ah well, i'll probably end up trying to get a student discount and just buying the license for my controller anyway, was hoping to be able to use some custom OSC to MIDI mapping at some point
geposted Sat 28 May 22 @ 9:23 am
Custom mappings are only available with Pro Infiinty or Pro subscription
