Got a few video samples with alpha channels, properly encoded as HAP with Alpha. I have verified that if I drag these same files into Premiere or After Effects, the alpha channel is there.
Unfortunately the VDJ Sampler is ignoring the alpha channel completely. If I drag the "transparency" knob up a tick, I get some transparency, but all the black in the image is also transparent, and has rough edges where there should be shadows.
I'm on Monterey 12.4 on a M1 Max, VDJ 8.5-arm b6921
geposted Mon 30 May 22 @ 7:37 am
Worked fine with some HAP files I tried earlier.
will try again
will try again
geposted Tue 31 May 22 @ 12:45 pm
Thanks for trying. Are you on Windows or Mac?
If it's working on your end, may I send you one of my files to try? I'm using the open-source HAP encoder for Adobe Creative Cloud but it's always possible it's making non-standard files.
geposted Tue 31 May 22 @ 1:05 pm
I also tried with the Quicktime Animation codec including alpha, and still no-go.
geposted Tue 31 May 22 @ 1:11 pm
windows..
here is a short test video i did with HAP samples ages ago.. when testing it back then
But i will test again, maybe something changed, or maybe its on mac issues are
geposted Tue 31 May 22 @ 1:19 pm
That looks great! And it's how it used to look the last time I used HAP samples a couple years ago. But something has changed and now it ignores the alpha channel in my videos.
geposted Tue 31 May 22 @ 1:50 pm
Samples with an alpha channel were indeed not working correctly yet on M1 macs.
It will be fixed in the next update
geposted Tue 31 May 22 @ 4:56 pm
Thank you Adion!!!
geposted Tue 31 May 22 @ 8:11 pm
Just a quick note to report that the new build 6978 did NOT resolve the issue for me on an M1 Max. I saw it mentioned in the changelog but the alpha channel behavior is still the same, unfortunately.
Cheers.
Cheers.
geposted Sun 05 Jun 22 @ 9:28 am
Could you send me one of your samples? It was working fine for the hap samples i have here.
geposted Sun 05 Jun 22 @ 1:06 pm
Sure, what is the best way to send?
geposted Mon 06 Jun 22 @ 10:25 am
Actually strike that, it's working! Turns out I have to remove the samples and re-add them to my sample banks, then it starts working. Thanks for the fix!
geposted Mon 06 Jun 22 @ 10:30 am
