Seems that the pitch_bend command does not honor the keylock setting. Is there another command that has the same "bend" function (to manually realign your mix) but without changing the key of your song?
geposted Thu 02 Jun 22 @ 10:42 am
nudge
geposted Thu 02 Jun 22 @ 10:43 am
pitch_bend doesn't change the key
geposted Thu 02 Jun 22 @ 10:44 am
It seems to change it a little bit. It changes, then snaps back, then changes again when you release pitch_bend.
I thought I was imagining it at first but I recorded a video with a sine wave and I can definitely hear something. Unless I'm crazy (which of course is a possibility, actually a likely one)!
https://streamable.com/7dknwl
geposted Thu 02 Jun 22 @ 1:43 pm
