Hello guys.
Need some help. My hard drive is dying so i will be changing to a new one.
I know that if i copy the database and history folders over i can get that but what about play count?
i noticed that when i copy some songs over even if i copy the database the play count is not accurate. any way i can transfer that?
thank u
thank u
geposted Sun 05 Jun 22 @ 6:52 pm
The play count is in the database file.
geposted Sun 05 Jun 22 @ 7:02 pm
yeah but what if i change folders to the songs? seems like its not recognizing them as played if they are in different folders :/
bcs if i change to a new hard drive the path will probably be different so what does that mean? no play count?
geposted Sun 05 Jun 22 @ 7:22 pm
like for example. my hard drive is called 2019, i got folder A there with 10 songs all show play count on the new pc after i transferred the database.
but if i copy that folder on one of the pc hard drives and open that through virtual dj instead there is no play count for the songs.
geposted Sun 05 Jun 22 @ 7:28 pm
sorted
geposted Sun 05 Jun 22 @ 8:00 pm
Hi how did you get sorted? I've been able to get all my history transfered to my new laptop but no the playcount or cue points?
geposted Sun 25 Aug 24 @ 7:16 pm
