While maintaining and creating my playlists, I noticed today that a function has been changed for the worse since version B6978 ff.
With version B6921 it still worked correctly.
If there were duplicates in a playlist in the automix area, the lower (last) duplicate songs were removed when clicking on "Automix Options" > "Remove Duplicates" up to version B6921.
Since version B6978 the upper songs are removed.
This is very bad and certainly not programmed out on purpose. Can this be undone please?
Many Thanks
Many Thanks
geposted Fri 17 Jun 22 @ 11:59 am
Confirmed in current EA, it's deleting the upper duplicates and leaving the bottom one.
Not sure what the previous behaviour was though.
geposted Fri 17 Jun 22 @ 1:13 pm
According to changelog Build7014
Is now partially fixed
With the new Build7014 it works a little better again that the lower duplicates are removed.
However, not with one click and not reliably.
You now have to click "Remove Duplicates" several times so that all of them are removed. And then not always the lower ones first!?
geposted Mon 20 Jun 22 @ 8:25 am
fixed with update BUILD 7021 (2022-06-20)
-Fix removing multiple duplicates from automix
Perfect as before! Thanks!!
geposted Tue 21 Jun 22 @ 3:02 pm
