Last week, I updated my copy of Virtual DJ only to discover this morning that starting three of the four decks is no longer playable through the external keyboard device!
I can start deck 1 with a keypress from the assigned key on the external USB device, but the rest of the keys only cause deck one to very briefly start then stop instead of commanding the assigned deck to play.
Not assuming anything, I am all ready to rebuild the keypress codes for the device itself, but the VDJ settings tables have me baffled again!
I am trying to enter a play key sequence for each of the four decks I have on my skin. Can anyone provide a step-by-step process for doing this? My next internet show is at 2PM CDT Friday. I can operate without it, but having the keypad programmed will make it a LOT easier for this old fart...
Thanks in advance!
Thanks in advance!
geposted Thu 23 Jun 22 @ 4:23 pm
I'm not sure I understand you correctly...
But if I were to script 4 keyboard keys to specifically play / pause 4 specific decks I would simply use:
deck 1 play_pause
deck 2 play_pause
deck 3 play_pause
deck 4 play_pause
deck 1 play_pause
deck 2 play_pause
deck 3 play_pause
deck 4 play_pause
geposted Fri 24 Jun 22 @ 9:06 am
Yeah, I guess I need to rephrase my question....
I can find the keystrokes for playing decks one and two (Alt-1 and Alt-7, respectively) but I can't seem to locate the ones for deck three and four...
Once I can find those play keystrokes, I can re-program them into the external USB keyboard device...
geposted Sun 26 Jun 22 @ 9:53 pm
EUREKA!
I reprogrammed Alt-1 to Alt-4 to "deck x play" respectively successfully!
Now, all I have to do is reprogram the USB keyboard appropriately.
Thanks!
Thanks!
geposted Sun 26 Jun 22 @ 10:03 pm
ackerdackerly wrote :
EUREKA!
Thanks!
Thanks!
geposted Sun 26 Jun 22 @ 10:04 pm
[quote=ackerdackerly]EUREKA!
Thanks,
Thanks,
Thanks, KLAUSMOGENSEN!
geposted Sun 26 Jun 22 @ 10:05 pm
