Hi
I am looking for the function which the song enters the loop automatically.
my intent is that when I save a loop (usually towards the end of the song) and I want that when the song reaches the point of that loop, it will enter the loop automatically without me pressing the loop button.
Thanks Yalon
Thanks Yalon
geposted Wed 29 Jun 22 @ 6:24 am
          POI editor
       geposted Wed 29 Jun 22 @ 7:12 am
          Another way to have the Saved loop active at the end of the Track, would be to assign the action loop_load_prepare to the ONSONGLOAD key of your keyboard mapping, but only 1 loop can be active at the time, so if you try to use loops in between you ll have to trigger the action above again.
You could of course have that action on a custom button and trigger it when near the end or when you are sure that no other loop in the Track will be used.
geposted Thu 30 Jun 22 @ 5:42 am
          so could you be just a bit more specific?  I think I've got a loop setup just as yours, but it is not engaging...
       geposted Thu 21 Jul 22 @ 7:39 pm
