Ok so I recorded a set in 2 parts.
I then combined the 2 sets I recorded using Audacity.
When I loaded up the track only the first half of the mixes tracks showed up in the hot cues (it’ll show the track title where it starts playing).
So I then closed out VDJ and located the cue bin file from the 2nd mix I did.
I used note pad on a Mac to combine the files. I corrected all the times but when I reopened VDJ the 2nd half still didn’t show up in the cue points.
It’s only 23 tracks long so is there a limit or am I not combining the cue bin files together properly??
geposted Mon 04 Jul 22 @ 2:56 pm
The cue points are stored in the database. Currently vdj only writes cue files but doesn't read them
geposted Mon 04 Jul 22 @ 3:56 pm
Aah ok that makes sense. So if I want them to show I’d basically have to play the mix and add them then name them again.
geposted Mon 04 Jul 22 @ 6:58 pm
