I'm having problems using the resize extention. I can set the size I want and it works fine when I turn resize on and off. However, when I close the program and re-open it the resize feature goes a bit loopy.
After restart if I activate the resize it puts my image half on/half off the screen and the resize feature is frozen. This means I'm unable to resize again.
I then have to uninstall the resize extention and install it again before it works again ...until I close VDJ.
Anyone got any ideas?
geposted Thu 07 Jul 22 @ 1:17 pm
resize extension ?
geposted Thu 07 Jul 22 @ 4:04 pm
Resize Extention = The plugin you install from the Effects/videoFx in Extentions in the settings menu.
geposted Thu 07 Jul 22 @ 4:12 pm
Better post here.... https://virtualdj.com/forums/235239/addons/Resize.html
More chanced for the Author to see and comment
geposted Thu 07 Jul 22 @ 4:43 pm
