Hi folks!
I'm changing between Virtual DJ and Traktor Pro and unfortunately get confused regarding the channel levels and clipping risks.
I'm wondering whether it leads to clipping when i take a channel's gain to the max by the gain knob itself or the equalizer (bass), when the master max level is out of sight.
I ask this because in Traktor Fora i read it doesn't matter how hard I overdrive an internal Traktor channel, I only should focus on the master level. When I once tried this approach with Virtual DJ, I got the impression it sounded bad.
Can someone please give me advice how to handle this within VDJ!?
Greetings from Jena, Germany
Matthias
Matthias
geposted Mon 11 Jul 22 @ 8:14 pm
It depends on your audio setup.
If you use internal (software) mixer then indeed the master is the only thing you should really look after.
That being said, VirtualDJ has a built in limiter in master output that will prevent it from clipping.
However, being a "hard / brickwall" limiter means that once you start hitting it frequently, your sound will degrade (it will start "pumping" as a side effect of the limiter kicking in)
If you use external (hardware) mixer, then you should pay attention to each deck.
In this case VirtualDJ also has a built in limiter that works against each deck, preventing clipping of each deck separately. Of course the same rules apply: If you start hitting the limiter frequently, the sound will "degrade"
Finally:
VirtualDJ only offers a hard (brickwall) limiter as a last means to prevent clipping/distortion.
It does not offer a "soft" (or soft knee) compressor/limiter as Traktor does.
If you want such a compressor, you can use any VST effect you like on the master output.
Finally:
geposted Tue 12 Jul 22 @ 12:57 am
Thank you very much, dear Phantomdeejay!
If you're used to analogue mixers it just feels so strange to let a channel escalate. 😄
Have a good time!
Matthias
Have a good time!
Matthias
geposted Tue 12 Jul 22 @ 2:08 pm
