Hello. I own a numark nv2 and vdj pro infinity on a Mac . When I plug my contrôler I make sure that my audio out is set has a separate deck. Hardware nv2. All the 4 Chanel’s works. The light are going up. When I push the cue button I see it’s selecting on vdj but I have absolutely no sound from the headphones. If I select on vdj the output is master and headphones, the headphones work so means the contrôler and headphone works. Any idea?
geposted Mon 18 Jul 22 @ 1:41 am
You cannot set NV2 as "separate decks" (Hardware mixer) output.
The sound of channels 1+2 is routed on the "master" output of the device, and the sound of channels 3+4 is routed on headphones output.
No matter what you choose in software, that's where the sound is gonna end up.
That's how the device was designed. It's not a limitation or a problem.
geposted Mon 18 Jul 22 @ 7:08 am
