Forum: Report a bug
Topic: small bug while changing skin
if you have a skin called test.zip and another one called test.xml and test.bmp (not zipped so)
vdj will list two entries but even if you try the two entry only the zip file is opened I think vdj should remember the extension to use for each entry in the skin list.
Y
geposted Tue 10 Jun 03 @ 4:40 pm
