Having problem for the first time since I dont know when..
Vdj will shut down when I try to go into Info (beside sideview) in the browser.
Is there anyone who can confirm this?
geposted Sun 04 Sep 22 @ 3:01 pm
No problem here with Info tab.
Which skin are you using?
geposted Sun 04 Sep 22 @ 3:15 pm
Fruit skin, but have tried to use default to with same results.
Can you see report/log from my computer?
geposted Sun 04 Sep 22 @ 5:07 pm
No crash seems to be logged unfortunately.
Can you try to rename your settings.xml ?
geposted Sun 04 Sep 22 @ 5:50 pm
I tried and it worked fine, but I dont want to edit all stuff again :(
Build 7093 and works fine.
geposted Sun 04 Sep 22 @ 6:09 pm
Can you send me the renamed settings.xml so I can see if it crashes with that one for me too?
geposted Sun 04 Sep 22 @ 6:43 pm
Thanks, that settings.xml and the fruit skin worked fine for me too though.
Some other things to try:
-Select an empty folder (root like Local Music would do), restart vdj and then try to open the info tab.
If that works, perhaps it's related to the specific file that was selected before opening the info tab
-In options, reset infoviewColumns by pressing the X on the right side.
geposted Mon 05 Sep 22 @ 6:48 am
Updated and did the reset on infoviewcolumns, now it works :)
Thank you for the best help Adion !
geposted Mon 05 Sep 22 @ 1:39 pm
Great, although not sure why it crashed for you though.
It did still have 'harmonic key' as column in there, which was removed and replaced by the keyDisplay option a long time ago, but that still showed up as just a second key column here.
geposted Mon 05 Sep 22 @ 1:50 pm
Now I found out that when I was editing in the fields in the infoview i could make it crash again.
I hope this help you in any way, I will have the fields in default for now.
geposted Mon 05 Sep 22 @ 2:12 pm
Try to add the fields one at a time and restart in-between, maybe that can show which field was repsonsible?
geposted Mon 05 Sep 22 @ 2:50 pm
Problem found, could happen with some tags, should be fixed in 7124
geposted Wed 07 Sep 22 @ 7:35 am
Thank you !!
geposted Wed 07 Sep 22 @ 2:03 pm
