I have one drive as a backup just in case my hard drive fails while I'm djaying. However, if I choose a song from the one drive it then continues to download it to my PC but I don't want it to download I rather it stay in the cloud and I use it with the internet when required. How do I do this? Is it possible? I can't seem to find the answer anywhere.
geposted Wed 07 Sep 22 @ 2:18 pm
no, you need the song on your harddrive in order to play it.
what you need to know is that your songs ARE up in the cloud and as virtualdj starts opening your music files they will download and stay on your computer.
what you would have to do OCCASIONALLY is just tell onedrive to empty your files back to online only so it frees up your harddrive again BUT as you continue to play your music they will keep coming back.
I use onedrive and have a 1tb plan thats full. my laptop is just 500mb so therefore it cannot fit the whole collection in at once.. but it works on-demand for me just fine.
geposted Wed 07 Sep 22 @ 8:45 pm
Thank you :)
geposted Fri 09 Sep 22 @ 9:59 pm
