Topic: Mapping EFX to Reverse Toggle on NS7III
Hello, looking for a little help. I'm not very good at writing the commands when mapping. I was able to map an Echo EFX to the Reverse Toggle button. It activates when I push it down. My problem is it stays activated when I push it up and have to do the process again to deactivate it. I would like to activate it when it's in the downward or on position and deactivate it when it's in the up or off position. Thank you in advance.
geposted Tue 20 Sep 22 @ 4:31 pm
What did you write there?
try
BLEEP -----> effect_active 'Echo EFX' while_pressed
REVERSE -----> effect_active 'Echo EFX' while_pressed
Thank you for your response:
effect_active 'echo'
When I depress the toggle switch it activates the effect but when I return the toggle, I have to depress it again to turn the effect off.
The while_pressed part should fix that
As an example this is my re-mapping of my NS7 mk1
The toggle/paddle part starts at 6:05 - all the scripting is linked in the video description
I will try this as soon as I get home. Thank you very much for your assistance!
then:
-----> effect_active 'echo' while_pressed
Thank you both very much! Trying it now!
Worked perfectly!!
