I have successfully mapped the RANGE button to triggera 4 bar loop on and off. Pretty straight forward. I have also mapped the + & - PAD PERAMETER to double and half that loop respectively.
Here is my problem….
When I’ve extended that loop to 8, 16, 32 etc and I want to release (or turn off) that loop, it doesn’t just disengage the entire loop (like I need it to). It incrementally shuts them off in descending order. So it takes multiple presses of the RANGE button to finally shut off the entire loop.
How do I map it for the RANGE button to turn on & off the entire loop, no matter the. length , in one click?
Thanks in advance.
Thanks in advance.
geposted Mon 26 Sep 22 @ 12:05 am
Or maybe the issue is the way I’ve mapped the PAD PARAMETER. They are mapped to “double” and “half” respectively.
geposted Mon 26 Sep 22 @ 12:21 am
