Hi there,
I usually use an Traktor X1mkii to trigger the internal effects of VDJ, but in some bigger Clubs I use an Pioneer DJM-900 Mixer, I know it has it's own effects, but for some reasons I'd prefer to use the internal ones of VDJ (because I have some Macro combinations programmed for Echo Out ect.)
What I have to do? Or as an alternative, is their a Way to trigger the Pioneer-Effects from my X1?
Thanks for help
Thanks for help
geposted Tue 18 Oct 22 @ 11:09 am
You can't trigger Pioneer built in effects from your X1
However you should still be able to trigger the software effects as usually.
The only drawback (depending on how you use your effects) is that you can't have post-fader effects with an easy way. This means that for an echo out effect you'll have to leave the channel fader open until echo dies as an example.
geposted Tue 18 Oct 22 @ 12:50 pm
But what have I to do? The internal Effects work perfect with my Controller, but on the DJM-900 they're complete silent
geposted Sun 23 Oct 22 @ 12:56 pm
