Topic: "Go to" alternative option
There in anyway to edit or alternative GO TO FOLDER, like Go TO playlist or Go to Album?
I mean that nowdays i have all my tracks in just one folder, so Go To folder is not usefull. so i start to think to improve this option.
geposted Sat 22 Oct 22 @ 4:08 pm
you can go to a playlist with the browser_gotofolder script, as for album where are you going to goto when you only have a folder?
you can already quick filter, or search by grabbing some meta data, I can't think of any other needed way, all possibilities are covered.
search `get_album`
i dont know how to use get_browsed_album
or get_album script
it's literally what I typed, you will have to have album as a searchable field.
search `get_album`
i got , i use custom buton, than search the album from each deck...thanks
any way to do this for a select track in the browser?
same idea but the action to put in between the ` ` is
get_browsed_album
