Hi there, I’m a paid user of vdj. Recently I’ve noticed that the small pads in the bottom right of deck 2 are showing hi hate 1/2/3/4 then underneath showing the same samples.
Deck 1 is showing kicks underneath.
How do I get my kicks back under the deck please?
geposted Sat 29 Oct 22 @ 7:35 pm
Added a picture for explanation
geposted Sat 29 Oct 22 @ 8:18 pm
Hi,
toggle the Pad View to default and change the Padpage.
geposted Sat 29 Oct 22 @ 8:26 pm
Thanks Danny,, found it. It’s set to default.
geposted Sat 29 Oct 22 @ 8:28 pm
No matter what sample pack I choose, buttons 1-4 are the same as 5-8
geposted Sat 29 Oct 22 @ 8:30 pm
look here. I think you have activate Split Page with a second Sampler.
With SplitPage you can the bottom 4 Pads change to Pad 1-4 from an other PadePage.
geposted Sat 29 Oct 22 @ 8:41 pm
You can’t have two samplers selected. I’m at a gig at the moment so can’t reset. Very frustrating though as I use the kicks to beef up slower songs. I’ll just muddle through and reinstall tomorrow
geposted Sat 29 Oct 22 @ 8:51 pm
So just to reawaken an old post.
New MacBook, same issue. Only when I plug in my controller. Without my controller, the pads appear normal! Anyone else seen this before?
geposted Fri 12 Apr 24 @ 6:24 pm
It's the "auto" mapping, I never got on with it.
remove "auto" from the colour, action and name and it will be fixed to the numbers specified no matter what.
geposted Fri 12 Apr 24 @ 6:44 pm
Sorry mate, wheres the auto option? Tearing my hair out haha
geposted Fri 12 Apr 24 @ 6:50 pm
in the padpage editor
geposted Fri 12 Apr 24 @ 6:58 pm
