STEM CREATOR.
Has anything changed there?
geposted Thu 17 Nov 22 @ 1:31 pm
I don't think so. It shouldn't have to
The resulting format is (basically) the same for pre-computed STEMS as before
And all the STEM creator does is taking audio files and putting them into that format (Those should of course be stems files from a producer for the result to make sense)
EDIT: I just test it in the latest EA release, and it seems to me to work like before
It will look like it's using the old/fast engine - but that shouldn't really matter since no separation was done, because the track was always separated/never combined in the first place, so there is no difference in quality
geposted Thu 17 Nov 22 @ 2:29 pm
