Topic: Can I use VDJ to play Music Bingo?
I have searched this, but all I come up with is people saying BINGO! as in, "You've got it!"
I found one or two threads where someone asked the same question I had but wasn't really answered. Surely I can't be the only DJ hosting music BINGO.
I understand how to make a song automix after 30 seconds (or whatever timeframe I choose). Is there any way to make songs start playing at a certain point? For instance, I want all songs to start 45 seconds in. I've seen where you mention hot cues, but from what I can tell, that's programming one song at a time and it's not quick to change. I might play 30-second sound bites of 300 songs or more per night. This is not realistic. Just like I go to settings and change the automix to 30 seconds, I want to be able to open settings and change the start time at will throughout the night.
Right now, I am doing it manually, no automix. I put a song on deck and randomly start it anywhere in the song and let it play for 30 seconds. While it's not hard, it's just tedious.
This question has been asked since 2017, from what I can tell. Has anyone addressed this yet? or is there another DJ program out there that can handle this? A lot of DJs use Spotify for Music Bingo. I would rather not. I have my own extensive music library and see no need to add their monthly expense to my pocket when I've already paid for this service.
Thanks for any help I can get!
geposted Tue 22 Nov 22 @ 4:17 am
It's a rare wish and every time it has differences on what is wanted exactly.
moving mix points is probably a no go because it would kill normal automix.
making 30 second samples is another way, it has merits but even automated it would be time/space consuming to do.
3rd idea [probably the one I'd do] automated repeating script, load a track, jump to 45s, place a named hotcue, jump 30 second, add apoi to jump to the end if a var condition was met, load another track do all that again until all your desired tracks are marked. All automated.
after that I'd have a button called "bingo" that set the var condition and set up relay play [not use automix]
and I'd also have, ONSONGLOAD check for the var condition and have it jump to the named cue on load.
Like I said everybody [of the few wishes] wants something slightly different so it's never really been tackled.
Let's give it a try:
Load a few tracks on playlist
Button 1, named "BingoPrep" (Bingo Tracks Preparation)
repeat_start 'PrepFiles' ? on & repeat_stop 'PrepFiles' : off & browser_window 'automix' & browser_scroll 'top' & repeat_start 'PrepFiles' 1000ms & load & wait 500ms & goto 20% & set_cue 80 & goto +30000ms & set_cue 81 & cue_action 81 'var_equal "$BingoGame" 1 ? deck 1 is_audible ? deck 2 goto_cue 80 & wait 200ms & deck 2 mix_now_nosync 2000ms & wait 5000ms & browser_scroll bottom ? set "$BingoGame" 0 : browser_scroll +1 & deck 1 load : deck 2 is_audible ? deck 1 goto_cue 80 & wait 200ms & deck 1 mix_now_nosync 2000ms & wait 5000ms & browser_scroll bottom ? set "$BingoGame" 0 : browser_scroll +1 & deck 2 load : nothing : nothing'  & browser_scroll 'bottom' ? repeat_stop 'PrepFiles' : browser_scroll +1
Button 2, named "BingoGame" (It starts/stops the game)
var_equal '$BingoGame' 1 ? on & set '$BingoGame' 0 : off  & set '$BingoGame' 1 & crossfader 50% & browser_window "automix" & browser_scroll 'top' & deck 1 stop & deck 1 load & wait 500ms & deck 1 goto_cue 80 & deck 1 play & browser_scroll +1 & deck 2 load
Button3, named "BingoClear" (Optional, remove the hotcues of the first button)
repeat_start 'UnPrepFiles' ? on & repeat_stop 'UnPrepFiles' : off & browser_window 'automix' & browser_scroll 'top' & repeat_start 'UnPrepFiles' 1000ms & load & wait 500ms & delete_cue 80 & delete_cue 81 & browser_scroll 'bottom' ? repeat_stop 'UnPrepFiles' : browser_scroll +1
Thank you I will try this in the next few days and let you know. Thank you so much!! You would think, as popular as this game is (it bores me to tears but pays the bills), that someone would create software for it. I need to be able to change the start point reasonably quickly and easily (or in the length of time it takes to play a line dance or two during a BINGO break). Although I have a lot of themes set up, it would automatically expand the library of themes. That way, I could use the same set of songs and cards, but the songs always sound different. It's not always the same clue. I'll see if your code gets me closer. Again, thank you!
I guess it depends on which part of the world you're living.
Over here (Europe) we don't usually do/have such games. Maybe sometimes for kid parties :P
Anyway, if you want to change location and duration of the song(s) you need to modify the preparation button.
Specifically the goto parts (not goto_cue)
goto 20% goes to the 20% elapsed location of the track and sets the beginning.
goto +30000ms advances another 30 seconds (1 second = 1000ms) and sets the end.
So, by changing just those two numbers you can change the parts of the songs being played.
PS: You can "prepare" different files with different values if you want, and then put them all together in your playlist to play.
The current solution is not 100% clean, but it should get the job done.
I have been using VDJ for Music Bingo for several years. It works great. Here is how I use it. First I Create a Music Bingo Folder of MP3 songs based on the Game. For Example " One Hit Wondres" and Music Bingo cards based on the the folder of Music in that folder. The Music Bingo's secrete sauce is the program that creates the Music Bingo Cards. ( My Secret). I then create an Automix playlist and shuiffle it once and sometime I move songs around in the Automix Playlist just to get a good music flow. I Then save the Automix Playlist for future games. I then create a slideshow of about 7-10 slides which is just advertising for me and the venue. I also download the "Title" Extension, which has the yellow banner with the Artist/Song info. I set the 'title" settings to come out at abpout 15 sec and close the title after about 40 sec. I set the banner to appear at the bottom of the display. This gives me a visual timer mark to mix to the Next Song. When the banner pulls away or disappears I know its about time to mix the next song. You can also play some games with the "Title" turned OFF. I also set up a custom "Mix Next" button that I manually control. I prefer to do this manually beacuse I don't want to set the mix to a defined time period of 40,45 50 seconds. I prefer manual control because each song is a little different and some songs you want to play a little longer than others. When I use Music Videos I set the Automix "fade in" start for each video because a lot of videos have a lot of "junk" video footage at the start of the video. I Use the Automix "fade remove Intro/Outro" but you can play with this per your liking. If you had a predeined 40 second mix out, you would miss a lot of the key elements of the video/song. You can also set a "Mix Next" keyboard command. I also have my keyboard command set to the "M" key. So I have two keys for "Mix Next" a custom Key on the VDJ interface and a Keyboard Commend. My games are typically either by "Song Title" or by "Artist"
I have over 60 various Unigue Music Bingo Game Folders. I am currently performing Music Bingo 3-4 night a week ( Mostly Week Days). Most nights I am getting 60-80 people playing in Taverns and Community Events in South Carolina.
