Topic: Reloop Mixon 4 - Deck Swap Bug
When switching the left deck between 1/3 or the right deck between 2/4 via the software "swap" button, the deck controls fall out of alignment with the deck that is currently in the left/right slot.
To replicate this issue...
- Open VDJ and load a track onto decks 1 and 3
- In the software (not via controller) press the swap deck button on deck 3
- Press play on the controller
You will see that pressing play here should play deck 3 (since it has been moved into the main left deck position now), however it still plays deck 1. Additionally, the deck switch LED on the controller does not light up "3" when the swap button is pressed in the software.
geposted Sun 18 Dec 22 @ 8:20 am
Unfortunately, you will need to swap Left/Right Decks using the DECK buttons on the controller.
The Decks on Mixon 4 are "Hardware" layers, the firmware doesnt offer any MIDI Out message for the software (VirtualDJ) to use, so can only be selected via the DECK buttons on the controller.
Thanks for the response, I thought it might be something like that. I'll get used to it I'm sure. Might just have to endure a few unfortunate pause-on-wrong-track moments in the meantime haha.
